Mounting focus light on Ikelite SLR housing
Started by benns2 ·
  1. I haven't bought one yet, but I'm looking for a solution to mounting a focus light (probably Fisheye Fix LED) to an Ikelite DSLR housing. I have dual DS125 strobes with Ikelite ball arms.
    The setup I'm thinking of is an Ultralight triple clamp to replace the bottom clamp on one of the strobe arms, a short arm, the Ikelite clamp and a Ultralight Y&S strobe adaptor to attach to the light.
    If anyone out there is using something like this or has something that works really well for them with an Ikelite housing, I'd be very interested in their solution.
    Also, anybody out there using the Fisheye Fix LED focus light? Is it any good?
    Thanks for any advice offered!
    Cheers!
    Bruce
  2. I have the same basic setup as you with the Fix LED, but I have the Ultralight BA-IK quick release adapters. On the left one of those I have an Ultralight Neck Ball adapter (AC-NB) which puts the Fix light right in the center of my housing. It works fairly well, but since the light is mounted at a bit of an angle, any time you move it you have to adjust it in two axes. It not really that big of a deal though.
    As a focus light, I thought it did a good job, but my only comparison is to the modeling light in the DS-125s. I liked the ability to adjust the brightness, and found myself with it near the low end most of the time. Mine was also delivered with a diffuser, which I use all of the time. I was even able to use it for mandarinfish without any trouble.
    On the downside, on about the tenth dive the leak light came on for no reason and has remained on ever since. I sent an email to Fisheye last week, but have still not heard back from them.
    One last thing, I haven't tried it yet, but before my next trip I am planning on making a small red filter to put between the diffused and the light for night dives.
  3. Thanks a lot Doug. That was exactly the kind of info I was looking for.
    Cheers!
    Bruce
  4. Hi Bruce,
    We've actually just sold two triple clamp setups a customer in Connecticut. We offer both the BA-IK setup and the setup with the triple clamp. Let me know if you have any questions regarding our focus light setups, We'll be happy to assist you!
  5. Hi Bruce,
    I would like more info on your setup for attaching to the Ikelite housings. I use their 20D housing and while their C-lite setup works, it frequently needed adjusting after strobe placement and it also has a very narrow beam.
    Do you have any images of what your light setup looks like on a Ikelite housing?
    btw, your links in your signature don't all work...such as the focus light one.
  6. I would like more info on your setup for attaching to the Ikelite housings. I use their 20D housing and while their C-lite setup works, it frequently needed adjusting after strobe placement and it also has a very narrow beam.
    Thanks the links should work now, I think the link was old or we had a typo in there.
    Here's what the setup looks like. The base is generic but if you already have the strobes then we would recommend using a triple clamp at the base of one of your strobes, and the focus light would attach to that.
