from Edius to Flash
Started by PCDiver ·
from Edius to Flash
  1. Hi all,
    What is the best way to export Edius HDV footage into flash? I tried several test versions of cheap encoders but they don't give the best results.
    Any feedback is very welcome.
    Peter
  2. Peter
    If you have Macromedia Flash 8 installed then you will see the flv option in your output when you hit PRINT TO FILE from inside EDIUS.
    That enables you to encode FLASH clips straight from any timeline. Easy as. :D
