iTTL Options
Started by Nige Wade ·
iTTL Options
  1. I use a Nikon D200 in a Subal ND20 with Nikonos Sync connectors and am currently using Sea & Sea strobes in manual mode.
    If I wanted to achieve dual strobe TTL lighting what are my options?
    I've spoken to Peter Kay about using Seacam 150's but it seems it will be difficult to double up the strobes.
    Is anyone out there using Heinrichs TTL converter and Inons? (doesn't work with the S&S 90's)
    Are there any other options apart from housed Nikon SB800 speedlights?
    Nige
  2. If I wanted to achieve dual strobe TTL lighting what are my options?
    Not sure if this is what you're asking but I use the ND20 with two Ike DS 125's and the Ike TTL sync chord and connectors. My ND20 has 2 connectors on it. One that is manual only and one that accommodates the TTL. They both connect to a small circuit board in the housing. There is a switch on the Ike sync chord that allows you to switch between TTL and manual while in the water so I pretty much only use the TTlL connector on the housing. But as a backup, I have the standard chord that I can hook up to the housing for use with the 125's or my old 100a substrobes.
    Andy
  3. That's a great solution (the new Ike cord w/ built in converter). If you don't have Ike strobes, I think you can get the Heinrich's converter, or you can get the Sea and Sea converter which is "removable" if you don't want to use it.
    Check the Sea and Sea site to see if your strobes are compatible.
  4. I use the Ike ttl converter on one strobe and the Ike wireless dTTL slave on the other. With a Subal and a D2X. It does what you are asking.
  5. I believe the Ikelite convertor only works with Ikelite strobes.
    For my Subal-housed D200 with Inon strobes, I use the Sea & Sea TTL convertor III. It works well. The Heinrichs TTL circuit also works, although having a bare circuit board stuck to the inside of the housing with bubble gum isn't confidence-inspiring, and you can't switch from TTL to manual with the housing closed.
  6. I believe the Ikelite convertor only works with Ikelite strobes.
    Check out the Heinrichs site - they have a new in-cable iTTL converter, a la Ikelite, but for most TTL-capable strobes.
  7. Good pt Arcatus - I saw that new converter on the Heinrich's site and posted about it a few months ago.
  8. i used the subal d200 housing with dual inon z240 and s&s ttl converter.
    it works well. I think i still have the converter. If you are interested, i am willing to part with it.
