Filters
Started by e=me ·
Filters
  1. Wanted to know what are some good 67mm thread-in filters for blue water shots in 20-40 ft and 60-100 ft?
    I tend to use Hoya filters .........thanks.....
  2. Basically you have two choices.
    Magic Filters which come in a variety of sizes, they are not glass and can easily be fitted to any lens. Usually come in a pack of 3 and are very good and affordable. You need to add one to a uv filter and then screw to your lens. This is what i use for my photo setup.
    The other choice is UR PRO, they have a blue water and a green water filter. They are glass and come as prefitted threads. 67mm is readily available. More expensive than Magic filters but also more durable. This is what i use on my video set up.
