Hi,
I am hoping to get some ideas for a housing/camera combination to use for freediving videography. I've had a good look around on the forum and found heaps of useful info. It seems the Sony HC7 is pretty much accepted as the best option for cheap HD so this is probably the camera I'm looking at using.
Specifically, I'm after a housing for the HC7 that's:
- cheap i.e. 1k - 2k
- rated to 100m or more, 130m would be ideal. The Amphibico and L&M housings are rated this deep, but they look quite bulky. Those that have used them, how are they to swim with?
- as small and streamlined as possible as it's for freediving only. The Seatool HC7 looks great in this regard, but is only rated to 60m. Also costs a bit more than I was intending to spend. Are there any others out there of this ilk? I would probably be willing to put up with the inevitable obsolescence of a design like this in exchange for excellent streamlining.
Also I really want to avoid vignetting... being new to underwater videography I don't have a very good grasp of what causes it, but videos with cut-off corners look hopeless. Is it likely to be a problem with any of the above mentioned housings if I'm using their own wide-angle lenses - or in the case of Seatool, an Ikelite one? How do these lenses generally compare to Sony's standard ones?
Thanks in advance,
Dave
