Light & Motion Housings
Started by Gamehunter ·
  1. I am looking at purchasing a L&M housing from a friend and I know it is a Stingray II. He is not sure what camera it was set up for, all the housing look similar. I would need to buy a used camera to put into it but I was wondering if I would have to buy one that it is set up for or can it be nodified to accept a different camera? Is there on Sony camera that this housing would fit that stands out above the others?
  2. If you could post a shot of the camera mount tray and inside of the rear plate it should be possible to get an idea of the model.
  3. If you could post a shot of the camera mount tray and inside of the rear plate it should be possible to get an idea of the model.
    I will see if he can get em photos, he is about 4 hours away, can you purchase or refit the mount tray for other cameras? Is there a model number stamp on it? My main concern is buying an older housing and then not be able to get a camera for it.
  4. My Stingray II tray has "V50" machined large into the top of it. It's for the Sony TRV50 and TRV40.
