In an attempt to objectively compare the two INON closeup lenses I setup a comparison exercise to determine the minimum and maximum focus distances (topside) at three different zoom settings. Measurements were taken from the front of the lens and the Ikelite housing was fitted with the long (standard port).
The zoom settings were:
a) Wide - as wide as possible without vignetting
B) Med - at the longest macro setting on the G9
c) Max - Max zoom beyond the camera's macro setting
UCL-330
1. Wide - 1 cm to 26 cm
2. Med - 13.5 cm to 21.5 cm
3. Max - 19 cm to 35 cm
UCL-165
1. Wide - 1 cm to 15.5 cm
2. Med - 8.5 cm to 10 cm
3. Max - 10 cm to 13 cm
I think the UCL-330 will be the glass of choice...
