Looking for the specs and polarity of Ikelite Smart Charger..
Started by Phylo ·
  1. So I just received my Ikelite DS-125's and I had assumed they would come with chargers since they are so friking expensive, but allas I was wrong.. So I'm going to see about getting an after market charger and modifying ti to work with the DS-125's.. The smart charger is $99+ where ass I can get an after market charger and modify it to work with the DS-125 for around $35 to $40..
    I need someone to take a look at there smart charger and tell me all the voltages and stuff that they have on the bottom.
    Phil
  2. Anyone?? I know someone out there has a smart charger that they could read the specs off of the back for me!!
  3. no clue, my strobes use AA's.
    Just look at it from a - I have to charge these- kind of perspective. Assuming you have the plug needed...
    The battery packs are NiMh, which are chargeble at 1/10 of the capacityv in 14-15 hours is a good basis. These chargers give a specific current (A) and shoul be generally avaulable. I'm sure there's a value for Ah (ampere hour) on the battery to determine what current you need. Also, the working voltage should be there somewere.
    For faster charges you need a delta V-thing (measuring voltage during charging, there are some home-grown print plate ideas for that, but (at least for AA size) there is commercial stuff available.
  4. Is this what you were looking for.. Hope you don't blow anything up.. ;)
    Edited by samplin
