Inon Optical D Cable Set - New in Box
Started by kidsdream ·
  1. Cleaning out my stockpile of unused equipment.
    I have a (1) Optical D Cable/Cap W5 Set. This was originally designed for the PT-015 housing but would workd with similar OEM housings. This is new in the box, never been used.
    I also have a spair Optical D also new in its own box.
    Combined you can set up 2 Inon strobes (the clamp in the W5 set can support both cables).
  2. Hi Jeff,
    the optical D has the inon connection on one end and is unterminated on the other correct? If so, how much for the duo?
