Wide angle for the Canon G9
Started by WaterMama ·
  1. Hi
    Can someone tell me the best wide angle setup for the Canon G9 with an ikelite housing?
    Is there any other lenses I should consider?
  2. INON UWL-100 M67 and the dome unit. Make sure you get the short port for the Ike housing. HTH. Tim
  3. That about sums it up. I'm not sure if you'll want the dome unit for shooting babies and children. THe UWL-100 has a 100 degree field of view - which should be sufficient - and you won't get fisheye distortion.
  4. The Epoque works quite well too, which I'm pretty sure is the same as the Ikelite WA lens. Can't put the dome on it though, so if this is something you want, go for the Inon.
    Like Tim said, get the short port with the housing.
    Ry.
