Lightroom !
Started by PRC ·
Lightroom !
  1. How do I persuade it to export open a file in CS3?
    Paul C
    <Edit> there were two questions - as is traditional I found the answer to the first just as the post came live.
    Edited by PRC
  2. In either the Develop or Library module with the picture you want to open in CS3 selected go to the Photo menu and the fourth item down is Edit in CS3 (assuming CS3 has been setup as the default editor in the External Editing tab in Preferences) and the file will be converted to whatever format you have specified on the External Editing tab and opened in CS3.
    Shortcut is CTRL+E
