Hand Grip Carry Strap Leash
Started by betti154 ·
  1. All,
    I would like to know if it is possible to put the Sea&Sea carry strap clips on Aquatica grips. I don't know that I've describe it the best, so have attached an image with the clips circled.
    Thanks, Damien
  2. Damien,
    The short answer is yes.
    Feel free to give me a call if you get stuck. :P
  3. I make a custom made handle with aluminun and works perfect for handlers on boats and swim underwater too...
    Gustavo
    guscabana.com
    All,
    Thanks, Damien
  4. I make a custom made handle with aluminun and works perfect for handlers on boats and swim underwater too...
    Gustavo
    guscabana.com
    I made an even simpler handle for my Aquatica housing for passing to and from the boat - all you have to do is take 1/4" rubber coated steel cable and put heavy duty clips with metal rings on either end and you have a very cheap (<$10 - $15) carrying handle. I would post a photo but I am actually at work and my gear is at home. (And yes - I know this should be in the do-it-yourself project section)
    Good luck.
    Andy
