Problem with ikelite ds125
Started by vanveelen ·
  1. I am using an ikelite DS125 with slave sensor.
    Strobe worked fine on last dive.
    I recharged the battery back and now the strobe
    doesn't fire. The modeling light is working fine, fuel gauge
    shows full power, but strobe ready light doesn't go on
    and strobe doesn't fire.
    I did not drop the strobe or flood it.
    The strobe ready light blinks for a mili second when I switch it
    from "strobe on" to "strobe on with model light".
    I don't hear the strobe charging up either.
    Has anybody had the same or similiar problem and know how to
    solve the problem without sending it back to ikelite?
    I have already used the modeling light to enable me to recharge
    the battery pack, changed the slave sensor (I have a ds 50 as well),
    connected a single ikelite cord to the strobe as well and short the wires
    as per the manual description but no luck...
    Any help will be appreciated
    Nikki van Veelen
  2. Hi Nikki,
    FWIW I don't know of anything that will stop the charge pump circuit in the strobe not to work - thats the high frequency noise that you hear when you turn the unit on - other than a flat battery and it is not that in your case.
    Also when the strobe has charged up and then turned off then immediately back on all of my DS125's dump a flash.
    Sorry but - I think it is wanting a vacation at the repair station.
    Paul C
  3. Sounds like a dodgy connection between the battery and the strobe, or between the synch cord and the strobe. First check the female pin connections between the strobe head and the battery. Sometimes they get opened upa bit too much and don't make good contact with the pins. If one of the female connections seems a bit too "open" squeeze it with a small pliers. If that doesn't work, check the pins in the strobe's cord connection. Sometimes the same thing can happen there, or one of the pins gets damaged.
  4. I'd say it's the circular flash bulb that has gone, I think for that you have to send it away to get it replaced, I had similar once, when I got it back all was fine, oh and by the way they didn't even charge me for it.. Thanks Ike.
  5. Hi all,
    I know this is 5 years later, however I'm curious to know if you found a solution? I've just bought secondhand 2 x DS125 strobes - one of which has exactly the same symptoms!
    BTW - I knew one DS125 was poorly when I bought - mostly I was after the spare chargers & battery heads; the plan is to see what lighting I get with the working DS125 (with my existing 2 x DS160's for portraits) and then maybe upgrade it to a DS160 when I can afford to splash out again!
    Appreciate if you or anyone knows the answer to to this non-flashing strobe; whether it is a bulb or other.
    Heather
