Buttons on Sea&sea D300 housing
Started by tobbe ·
  1. Hi,
    I'm having a slight problem with the control buttons on my sea&sea D300 housing. Two of them just do not reach the camera (trash + play). The rest seem to work quite ok, but a few perfect.
    Anyone else that have the same problem?
    Edited by tobbe
  2. Hi,
    I had the same problem. I realized I left the camera LCD cover on and that made the difference. Make suer you remove the eyepiece rubber and the LCD cover. After that everything worked perfectly for me.
    alex
  3. Hi,
    alex
    Yah, this worked for me too (manual mentions the eyepiece but I think not the LCD cover)
    the LCD cover also impacts use of the shutter dial too.
    Manual warns housing could flood if the eyepiece is left on also.
    Once these were removed, all controls work perfect for me, although I did not try trash (dont trust myself to know what to delete until I see it on the big screen, or by accident delete the wrong image as a big wave comes in!)
  4. Thanks guys! I had also forgotten the display cover....
    Works perfect now!
  5. Thanks guys! I had also forgotten the display cover....
    Works perfect now!
    Looking forward to seeing some pics with the new setup !
