Nikonos strobes with Ike's iTTL
Started by Arnon_Ayal ·
  1. I just upgraded to D200 (I know, one step behind... B) ) , I'm going to get the housing just before entering the water so I won't have time for experiences.
    I remember there were talking about problem using the Nikonos 105 with the Ike's Ittl circuit, as I remember you need a new cable for that.
    Since I have the old one that I used with my non-TTL D70 housing I wonder if I can still use it and how (non TTL of course).
    Any help will be appreciated since I want to use my new equipment this weekend and not waiting for the new cables to arrive from the states.
  2. Arnon,
    Yes, same cable will deliver non-TTL firing as on your D70 housing......Bulkhead is the same on the back of all current model Ikelite dSLR housings......
    Hope this helps!
    dhaas
  3. Thanks, I read it before going to dive and work as you wrote with no problems.
    One problem I had is that I didn't understood why I don't have enough light all the time, it's took me two dives to realized that the D200 works at 100 ISO and not at 200 as the D70 :rolleyes:
    Arnon,
    Hope this helps!
    dhaas
