D3: Details of underwater housings
Started by Liz Hanks ·
  • 10Posts
  • 10Replies
  1. I put together and uploaded a table with everything I could find on the D3 housings that are expected to come out. I did a similar thing a while back for the HC3 when I temporarily switched over to video. The D3 table was a lot easier to produce though, since there are very few housings for it :-)
    Let me know if there are any additions or corrections. I'll eventually include links to reviews and relevant forum threads.
    Enjoy,
    Liz
  2. Thanks for the table. Very helpful to have in one place. I believe that the Aquatica will have the option of having two nikonos bulkheads or one ikelite style bulkhead, if I recall correctly.
    I've already made up my mind about the housing, but still very handy to see this.
  3. Thanks for the table!
    Now if only we can get some people to try out the D3 on D2x housings and see what controls are missing, and add it to the table...
  4. You're quite welcome.
    Thanks for the heads up. I haven't found this written down anywhere yet in the Aquatica literature, but as soon as we get more details I'll add them to the table.
    Berkley White already tried this out. His article is here, in case you haven't seen it. Since the D3 doesn't really fit into the D2X housings, and the D3 housings will have slightly different properties than their D2X counterparts, I think we just need to wait this one out and see what controls the new housings are in fact missing.
    Liz
  5. Hello Liz, for your spreadsheet: The Aquatica D3 housing will be available with the following variants:
    # 20058 : Double manual Nikonos Type Bulkhead (standard default set up) but is also available in 5 pins TTL on request for use with a TTL converter or a housed SB 800 flash.
    OR
    # 20058KM : Single Ikelite Bulkhead in manual 2 pins # 20058KM
    OR
    # 20058KT : Single Ikelite Bulkhead for TTL with 5 pins # 20058KT for uses with their iTTL converter.
    and also
    # 20058VF : this version includes the standard view finder as well as the Aqua View Finder.
    The Ikelite bulkhead is only available in single configuration and is 100% original Ikelite parts including the hot shoe assembly.
  6. Which of these housings can take Hugyfot Ports with an adapter?
  7. Sea&Sea Japan has announced the release of D3 housing on Mar 13, 2008.D3 housing is scheduled to be available in late Mar.
    http://www.seaandsea.co.jp/press/1205390447.html
    Construction: Body: Corrosion-resistant aluminum alloy (machined)/anodized body, grip: corrosion-resistant aluminum alloy (die-cast)
    Depth rating: 60m/200ft
    Dimensions (WxHxD): 355x220x121mm
    Weight: approx.3,150g (housing only)
    Price: JPY480,000
    Yoko
  8. I've received a lot of information from Aquatica, Sea&Sea, Seacam, and Subal reps since I first posted, so I've uploaded a new much bigger version of the D3 housings table.
    Please let me know if you see anything that needs to be corrected.
    Given ChrisJ's question about Hugyfot ports, I realize that extra information about port compatibility and adapters would be useful. When I get a new burst of energy, I'll tackle that one and any other suggestions.
    Liz
  9. You'll have earned that housing when it finally arrives, Liz! All your hard work is really appreciated.
  10. You'll have earned that housing when it finally arrives, Liz! All your hard work is really appreciated.
    You're quite welcome :-)
    It looks like I won't have to wait long. Backscatter has just gotten a shipment of ND3s from Subal. They're have the type 3 (older/smaller) port openings. There are some photos and notes from a first dive with one of these housings here. I didn't expect both the AF-On and AE-Lock buttons to be accessible simultaneously on any D3 housing, but it looks like from Berkley's report that you can with the ND3. Nice touch.
    The housings with the newer/larger type 4 port opening are due to ship this week. I should have mine next week and will hopefully get it wet the following weekend. Yay.
    I'll update the D3 housing table when I get home this evening. If anybody has updates on other manufacturer ship dates, features, etc., let me know and I'll make those changes too.
    Liz
    http://lizhanks.com/
