I'm having problem a problem to decide which Ikelite strobr to buy. I'm currently using a Nikonos RS and Nikonos V and will be upgrading to a Fuji S2 pro or some thing like it in the futher.
Now I'm deciding between twin Substrobe DS 125s or twin Substrobe 200s. I'm from Malaysia and there are no expect advice avaliable. We only have a disturbutor here whom, only orders stuff from ikelite for you and not sure how it works or perform. Don't ever ask about tests units.
Does anyone have any insight, or does any one have any other suggestions? All advice is welcome, and lots of thanks is advance.
I've been using twin 200s for the last few years. Above water they are heavy and bulky. Underwater they are only bulky. I've been pleased with the results but would probably go with twin 125s if I were buying today. They are significantly more compact, only loose an f stop compared to the 200s and can be used with Ikes variable controller. Coverage is similar.
Regards,
I like the DS125's better. They are a LOT smaller, and recycle extremely fast. As another Don noted, these strobes will work with Ike's 10 step manual controller - whereas I don't think the SS200's will. So if you're looking for more control than 3 power settings the 125's are DEFINITELY the way to go.
With that said, I think 3 settings (plus TTL) is plenty for me.
Question:-
What about some serious Wide angle stuff. I was ona trip recently, and I noticed the pro 's and semi pro's they were using some heavy stuff. Does the 125 have enough throwing power for wide angle ?. I have seen that the top Sea and Sea is only equivalent to the 125, and I think if you want more than that, you are limited to ikelite ( correct ? )
The 125s have 90 degree coverage which goes to 100 degrees with the diffuser (losing another stop). The 200s are 100 degrees without the diffuser Used as a pair I doubt that the 10 degree coverage difference is important.
