inon
Started by kento ·
inon
  1. Hi
    sombody ho can help me out whit this small problem
    going to trigg my inon strobe to my ikelite house
    one sad ting is a can not have the S-TTL mode more
    but thats allright for me have to learn in manual mode
    a no to switch main mode M-MODE (left knob
    but how do a set EVcontroll knob(right knob) when a go in water
    and start to take image need som hints help
    kent
  2. Hi
    kent
    Hi Kento
    im having a bit of dificulty reading your post . but i think you are saying that you are using an inon strobe fired by SYNC cable from a ikelite housing, in Manual mode??
    ill asume that your using a INON Z240 as thats the strobe im using. as you said set your main dial to M which allwos for manual controll of your strobe .
    i push the preflach button IN
    then set the EV Dial in the following position . for macro subjects i use position 2 shoot,, and dial upwards as required.
    for wideangle subjects i use position 11 shoot,, and dial down as required.
    after a while you will be able to aproach a subject and gues the EV dial setting fairly closley. as you probally also know mooving your strobes foward and back will affect the amount of light on the subject, also if you cant dial the strobe power down enough by the EV dial , mooving strobes back and Fstop there are various strength diffusers made by inon .
    All the best
    Reagrds
    Matt
  3. Hi Kento
    All the best
    Reagrds
    Matt
    [/quote
    Hi Matt
    it was really great help its more clear no assume you have this 2 F-stop as starting point right
    my inon strobe comes whit to diffusers . one is -1.5 fstop and the other is -0.5 fstop .
    if can"t dial down strobe power enough by the ev dial.
    my idea is to do it whit the cameras EV controll
    or change the internal flash output ???
    well at last a have plenty of time to spend i a pool and learn to to shoot in manual mode :D
    so thanks matt
    so long best regards kent
  4. Hi Kent
    it also might help if you share what sort of rig you have .(what model)
    camera , strobe housing ect .
    i would start with strobe diffuser -.5
    matt
  5. Hi Kent
    matt
    Hi Matt
    My camera is a Olympus E410 12-42 lens
    Strobe Inons Z-240.
    housing Ikelite + dome port 6.
    kent
  6. Kent,
    How do you fire the Inon strobes since the internal strobe can't pop up on the camera? Just curious....I was thinking of switching housings.
    Edited by ce4jesus
  7. Kent,
    Hi Gary
    In ikelite housing is not available to use pop up flash
    for fire inon stobe you mount ikelite synkcord but notice
    S-TT mode is not available only Auto or Manual mode
    Ikelite recommend following syncord for inon .
    #singel strobe. 4118.1
    dual strobe 4118.2
    Gary a assume you have the14-42 lens ???
    A email IKELITE about port and the recommend me
    go for the dome port 6 allso good for use of 50 mm
    macro lens.
    a E-mail ikelite to about if OLY E420 going to fit
    in 410 housing but ther was not sure about it yet
    but the told me the can not today confirm it ther is
    going to be a uppdate about that on ther webb site.
    regards kent p.s hope this help you
    Edited by kento
