Just a heads up. Using the MDX 40D housing. If you try to install the 500D closeup lens on the Canon 100mm macro in the DX Macro 50 port and base (Recommended on the System chart) it will have about .002 inch interference and scratch the inside of the port with the serated edge of the lens. It's very close. At first glance it looks like it will fit. Measurement with a vernier caliper just saved me buying a new port. Since this seems to be a fairly common setup I thought I'd put up the post. It might save somebody some money. I'm considering machining off some of the outer ring of the 500D to make it fit. Is there a practical optical limit to how close the lens can be to the port glass?
I wish S&S had thought about the 500D when they made the port. Another .10 would have been all we need. Guess they can't think of everything. ![]()
