Canon A570IS and Housing WITHOUT Strobes
Started by NeurosurgeryNP ·
  1. Does abyone have advice on this outfit without the use of strobes?
    I am a once or twice a year diver, who just purchased this camera and housing. I do not plan on investing on strobes at this point. I am an OW diver who does not plan to exceed the recreational dive limit. Mostly dive in the Caribbean.
    Does anyone have samples with this camera/housing with using strobes - just the natural/native flash and diffuser?
    Any advice on the use of this camera without strobes?
    Any help would be greatly appreciated.
  2. Does abyone have advice on this outfit without the use of strobes?
  3. hi, you will find that you can get good results with out a strobe for macro shots you will find the lens obstructs the flash & causes shading at bottom right of photo, so try & reflect the inbuilt flash with your hand or small metal disk. for wide angle try useing underwater white ballance setting if you have it & maybe increase your iso setting
