Setting White Balance on D200 inside Hugyfot Housing
Started by GLOC ·
  1. I have recently taken delivery of a D200 and Hugyfot housing and would like to know how (if it is possible) to set the WB whilst the camera is inside the housing.
    I shoot mainly deep wrecks with mixed natural and strobe lighting so I normally shoot RAW but if I can take out some of the colours at depth when shooting natural only it would be great.
    Regards
  2. I have recently taken delivery of a D200 and Hugyfot housing and would like to know how (if it is possible) to set the WB whilst the camera is inside the housing.
    Regards
    Yes, you can. There is a rotating knob on the top-left part of the housing where you can have pressed the WB button. Then, with the main wheels, choose the one you like etc...
  3. Yes, you can. There is a rotating knob on the top-left part of the housing where you can have pressed the WB button. Then, with the main wheels, choose the one you like etc...
    What I meant, is there a way that you store the WB like you can when the camera is outside the housing ie press and hold the WB button, rotate to PRE, press and hold WB again, fire shutter and capture that WB 'environment' and then use it as d0.
