Diopters and housing servicing
Started by StuartL ·
  1. I'm intending to take a Canon 5D underwater, with the 100mm macro or the 16-35mm II, depending on my mood and what I'm shooting. I've already started picking up bits and pieces of an Aquatica housing as I can afford them (Australia being what it is, there's very little local stock, so I'm getting them from B&H).
    The question is: is it desirable to put a diopter on the 16-35mm when using it with the 8" dome? Being an 82mm filter thread, there are no direct options available, but Schneider Optics do make a filter in the Series 9 size, as well as an adapter to mount Series 9 filters on 82mm threads (information I picked up from the uwphotochat forums.) Minimum focus distance for this lens is 28cm.
    The other thing that's bugging me: what should I do in terms of servicing the housing? Cleaning the easy-to-reach O rings is fine, but what about those that are a bit harder to reach? Is it particularly difficult or fiddly, or just time consuming? (Bear in mind that I'm an IT professional - I'm not used to doing fine work with my hands.)
    It looks like B&H carries the O ring kits, so that's one concern alleviated, at least.
    Thanks for any and all advice - I'm a genuine neophyte (at least for underwater SLR photography - I have a fair amount of knowledge on the surface), but keen to learn.
  2. Stuart,
    Hi be very sure the increase in length with a dioptre lens does not cause it to foul the inside of the port at full zoom. I wrecked a port that way.
    regards Tim Digger
  3. not sure about the dioptres.
    but, you can send your housing to your local dealer for servicing i would think
  4. Have you spoken to Peter Mooney at scubapix in Cairns?
    I know that he stocks Aquatica and his prices are dictated by import duties
    and not his hunger. He is a very helpful bloke and an Icon on the international scene... :unsure:
    If that sounds as though I'm laying it on a bit thick, give him a call, find out for yourself... B)
    HTH,
    Bruce...
    Edited by bruceterrill
