How to shoot competitive swimming uw
Started by Drew ·
  1. Landscape-oriented camera results in portrait shot. Neat trick ;).
    Looks like he just dropped a WFT-E1 in a Subal/Sealux/? SB-800 strobe housing and ran sync-cord between the two, with the housing modified to connect to the USB port. Sounds familiar :lol:.
    The Reuters press pass doesn't hurt either...
    Edited by segal3
  2. Yeah, but how did he get the cable from the transmitter housing to the surface? There's only one bulkhead on the housing. I wonder if he ported a second bulkhead.
    It looks like he's using UK - Germany gear.
    It's a great idea.
  3. Transmitter is wireless - no cable to surface required. One would only need a total of two bulkheads for the setup since no strobes are being used.
  4. Matt: the transmitter is in that flash housing on the bottom of the pool. Don't think it can wirelessly transmit from there but I could be wrong...
  5. Yep, that's the purpose of the transmitter. Canon lists a (rather generous) 150m/492ft range for the transmitter with antenna attached. Even if it drops to 10% of its working range underwater, that's still 50ft transmission radius.
    It'd be different if he just decided to run a long USB cable (or switch it to CAT-5 with one of the repeaters) for the same result, but an extra cable.
    Edited by segal3
