Removing oxid
Started by Pedda ·
Removing oxid
  1. Hi,
    I'll get my spare parts soon, so I'm on the way to take my Ike housing apart for service.
    I've got some oxide on a couple of the push-buttons and wonder what the best way to remove it is?
    I assume that it's not such good idea to put the buttons in the ultrasonic cleaner?
    Any suggestions? Vinegar?
    What about greasing the small o-rings for the buttons? Do you use the same amount as on the port and housing o-ring?
    Regards
    Peter
  2. Hi,
    Regards
    Peter
    Ultrasonic cleaner will work fine (I'm assuming the shafts are stainless steel). Same grease will work on all o-rings of the same color. If they're all black (Buna) a good quality silicone grease.
  3. I'll be happy to ear also about maintenance of the Ike housing, the maintenance page from Ikelite site give some information but not answer all questions.
    I'm thinking to give my housing for the local diler but not sure if it's not better to do it by mayself.
    Edited by Arnon_Ayal
  4. Ultrasonic will be fine.
    If things are really ugly Citric Monohydrate works well though it is a pig to get hold off since the addict community started using it to clean out used needles.
    We used to use Citric Monohydrate and warm water in an ultrasonic cleaner for cleaning really skanky second stages but you dont want to meke it too strong as it takes the chrome off !
    Good stuff.
    What does the second stage cleaning community use now ?
    Don't use any abrasives - better to leave the oxide deposit than any ridges in the surface that will abrade the O ring.
    Paul C
  5. Thanks for your answers.
    The only thing is that I'm a little bit afraid that the ultrasonic cleaner will "take away" to much of the material so that the o-ring will seal bad.
    Regards
    Peter
