Help needed for Nexus 5d/e-ttl
Started by shchae ·
  1. Hi,
    Is anybody using Nexus 5d housing with e-ttl function ?
    Nexus provide 5 pin sync connector + fiber optic connector and
    I could not find the way to use e-ttl.
    Sam
  2. Hi,
    Sam
    Hmmm, do you mean there are two separate bulkheads, one with a 5-pin connection and one with a fiber connection? Trying to picture what you have.
  3. There are no fiber connectors on the Nexus 5d housing. The 5d doesn't have a pop up flash...
    We can retrofit subtronic s6 connectors into this housing, allowing the external heinrichs converter to be used.
    http://reefphoto.com/index.php?main_page=p...roducts_id=2355
    We have installed the HW Mk1 converters in a Nexus 5d housing before, but it was very tight.
    If it were mine, I'd install the external converter which can be easily bypassed in case of a failure.
  4. Ryan,
    That looks very nice and a lot less expensive and bulky than my Sea and Sea eTTL converter ;-) (insert old-fart grumbling sound here)
    Does the Heinrich's also enable rear curtain sync when used in manual and TTL mode?
  5. Hi & thanks to every one. It was great help.
    Sam
