my strobe vill not fire
Started by kento ·
  1. hi
    whats is wrong my inon strobe vill not fire
    have running som test att home am using
    ikelite synk cord for inon strob
    how do a st the internal camera flash?????
    on the test a have don is S or A mode but
    the number on lcd flash all the time??????
    need som help
    kent
    olympus e410
    inon 240 strobe
    Edited by kento
  2. Does the Inon fire wirelessly with just the camera. Strobe should be set to s-ttl and the optical cap on the bottom of the strobe removed for wireless.
    Edited by ce4jesus
  3. Does the Inon fire wirelessly with just the camera. Strobe should be set to s-ttl and the optical cap on the bottom of the strobe removed for wireless.
    Hi am trigging my strobe by ikelite synk cord
    if you do that you can not not have S-TTL mode
    only Manual or auto mode
    a don"t think a should removed the optical cap
    but am not sure about that really
    kent
  4. Yes I agree. But to troubleshoot the problem, you can first see if the strobe will fire wirelessly. If it does, that will tell you the strobe is probably fine and you can begin troubleshooting your connections. I'd start with the hotshoe connection inside the housing and then the cord itself.
  5. Yes I agree. But to troubleshoot the problem, you can first see if the strobe will fire wirelessly. If it does, that will tell you the strobe is probably fine and you can begin troubleshooting your connections. I'd start with the hotshoe connection inside the housing and then the cord itself.
    HI
    going to do that but a think thers is som problem on the cord have just notice som small
    damage on the cord if that is the problem a don"t think my strobe is the problem it
    working very good wht my old camera and housing as you say. The problem seems
    to be on the cord or hotshoe connection but does the strobe fire whit out any synk cord
    connection??????going to try out that suggestion
    thanks for help
    regards kent
  6. HI
    thanks for help
    regards kent
    I faced a similar problem with INON Z240 with Ikelite sync cable. Ensure that cable is properly connected to the strobe. Even though it looked perfectly hooked inside, the thick O-ring there seems to prevent a proper mate, unless you push it hard enough, before you tighten the outer cap.
    Hope this helps!!
  7. I faced a similar problem with INON Z240 with Ikelite sync cable. Ensure that cable is properly connected to the strobe. Even though it looked perfectly hooked inside, the thick O-ring there seems to prevent a proper mate, unless you push it hard enough, before you tighten the outer cap.
    Hope this helps!!
    hi my problem is solve the hotshooe contact was not properly install in the camera
    but no everyting is working great
    kent
