Need advice on the strobe
Started by Akulamd ·
  1. Hello everyone! I need some advice - planning a trip to Indonesia on liveaboard for two weeks. I use Fuji S2 in Aquatica housing with 2 Ikelite SS200 strobes. I have recently found out that Ikelite stopped servicing the SS 200s. Any ideas on how SB-105s work with Fuji S2 (S2 has the same TTL circuitry as the film Nikon N80)? Alternatively, can someone suggest what to do/how to rebuild the SS 200 battery packs? Thank you very much in advance.
    Eugene
  2. If the S2 does, in fact, have the same circuitry as the Nikon '80' series film cameras, then it should provide 'real time' Nikon TTL. The other necessary items would be Aquatica's TTL compatible hot-shoe and TTL compatible sync cords...
    With all this in place, you should get Nikon TTL...IMHO
    This si of course with the Nikonos SB105 strobes. Ike's strobes have always been a different proposition.
    Bruce...
    Edited by bruceterrill
  3. The Fuji S2 was popular with U/W photographers because it supports standard Nikon TTL. I have friends who used TTL with the S2 in Sea & Sea housings with Nikon SB105s and S&S YS 90s.
  4. Thank you, everyone, for the response.
    Sincerely,
    Eugene
  5. BTW the DS 200 uses the same battery pack size as the SS 200.
    Any strobes that says TTL on it will work with the Aquatica S2 pro, this housing was supplied with 5 pins bulkhead (same as the 35mm cameras) I had one for the longest time and was using it with Ikelite Ai and/or Nikonos SB-105 with flawless result, that is, as far as I know the only Digital camera with straight plug and play TTL, just too bad the AF was so bloody slow.
