I just recieved the focus extension part #5510.75 Focus Extension
for the Ikelite modular port system for my Nikon 105mm VR. It works well with the port body intended for the Nikon 12-24mm 5510.22. This combination is preferred if you intend to use diopters. I tested this with the 5T and 6T and there is plenrt of room for either diopter or even both together. The port has just enough room to safely accomidate both diopters stacked but not much more to eat into your very short working distance with this combination. If you do not intend to use internal diopters I would recommend using the 5510.16 port body instead. With this combination the lens alone has less room in front making for a more compact port.
The focus knob works by turning a small paddle that brushes up against the focus ring on the lens. The shaft is slightly skewed and the paddle has a rubber O-ring on it to grip the focus ring. Its a slow operation perfect for precise focus, but not good for fast slewing. I would use this with my diopters but rather use AF and a good focus light if I can. Don't worry if the focus knob requires some pushing in to get it to grip the focus ring on land. Underwater, water pressure will take care of it. I tested this in Rocky Point on the demo last fall and it works great. Thankfully, the focus ring on the 105mm is wide, which makes this focus extension work with both port bodies.
The port comes with an additional spacer for the focus shaft that can be used with Canon 100mm lenses. The spacer allows the shaft to go in closer to the lens to accomidate the narrower lens diameter. To change the spacer you remove the shaft with the provided allen wrench and substitute the spacer.
A recent announcement is requesting users of the 105mm and the modular flat port to exchange their port bodies for a larger diameter version. My old style port body works OK here but its a tight fit and difficult to install without brushing the VR switch. I'll be sending mine back for the free update.
Te next step is to get it into the pool for a real test.
