james, you make a good point. how does the ethernet connect compare to a firewire 800 capable array for speed??
to avoid being overwhelmed, i've been looking b/w the readynas drives and the lacie arrays with esata & firewire 800 (which are cheaper)
If firewire's faster (don't have eSATA on my comp) what advantages would a networked array have if i have no real need to add the drive to my network?
any others I should look at or avoid??? thanx guys,
Chris
Gigabit Ethernet has maximum theoretical throughput that is about 25% faster than firewire 800 (1000Mbps vs 800Mbps). However, getting maximum performance from your ethernet connection is highly dependent on the quality of your network as well as the volume of traffic and often takes some tweaking to get it running efficiently.
NAS has several advantages/disadvantages depending on how you set it up. For me, I like the fact that I can automount my NAS via NFS when at home and it doesn't matter whether I'm sitting on the couch with my Macbook pro on my lap or hardwired at my desk in front of my desktop monitor; my data is always available without worrying about power or wires (granted that when you access it via wireless it's a lot slower). It's available to anyone I want to have access to it while there at my house and if I really wanted, I could set it up as an ftp server and webpage server. The big worry for me is that because it's on a network that is exposed to the outside world, there is always the chance that I can be hacked into and security is an even bigger concern since it's also available through a wireless network.
Firewire 800 is almost as fast theoretically and might be a little faster practically. The biggest advantage to firewire is it's plug and play. Plug it in, format the drive and you're ready to go. Depending on what you get it's portable and if you have little 2.5" drives you don't even need an external power source.
At 3Gbps, eSATA is buy far the fastest interface. But realizing it's full potential doesn't often happen. Most laptops don't have a express34 slot or eSATA port, so you may be down to a cardbus adapter. The problem there is that the cardbus specification has a maximum throughput of 1Gbps.
In your case, if simplicity is king and the advantages of NAS aren't compelling, then firewire is a good way to go.
Mike
