Which lens to use? recommend
Started by yhmah ·
  1. I have a Nikon D200
    Housing is with a Fisheye Dome Port
    Which would be the best prime lens to use
    I own these Nikon Wide angle and Fisheye lenses
    10.5mm FE DX
    16mm FE
    18mm
    20mm
    Also the 12-24mm DX
  2. I have a Nikon D200
    10.5mm FE DX
    16mm FE
    18mm
    20mm
    Also the 12-24mm DX
    Both the 10.5 and the 16 will work with a fisheye port without additional extensions (at least with Subal)
    The 10.5 will be a true fisheye on the D200, the 16mm will act more like a superwide on the D200. The 12-24 will require an extension. (I am not familiar with the others). I guess best depends on what you want to shoot.
