Help Critical - New Ikelite D300 housing missing seals? Compare yours to mine please...
Started by RVRinTAS ·
  • 14Posts
  • 14Replies
  1. Hi all,
    I just got my new D300 Ikelite Housing, and was having a good look at the inside of it... This may apply to ther Ikelite Housings, not just D300...?!
    I then notice that the bolts the hold the top clip (used to latch the cover closed) - had some black seals under the bolt heads on the inside...
    Then I noticed that the left and right clips had these missing... I can't seam to see any other seals for these bolts...
    If you are reading this, can you please have a look at your housing and see if yours has these and please post a reply here to tell me what you see on yours... Do you have all the black seals under all the bolt heads...?
    Some pics here to help out.... Link to Google Pictures
    Edited by RVRinTAS
  2. Hi All - OK - I just got the torch out... Not sure why they don't all have the little black things...
    BUT
    The seals are a set of 2 o-rings on each bolt shaft within the wall of the housing...
    Any one want to confirm my findings?
    Edited by RVRinTAS
  3. You might get a definitive answer if you contact Ikelite directly about your concern. At least that way, if there is a problem, you can tell them you spoke to them about the issue prior to using the housing.
    You can also do a pressure test on it without the camera.
  4. You might get a definitive answer if you contact Ikelite directly about your concern. At least that way, if there is a problem, you can tell them you spoke to them about the issue prior to using the housing.
    Sounds like good advise.
    I have to ask the obvious " What was wrong with asking the store you got you housing from" ?
  5. Hi - It is 12:10am here, and all shops are closed (including the store I bought the Ike gear from) - I will call off dive for Tuesday and look in to it...
    I was using the forum to see if Ikelite housings were the same...
  6. Hi - It is 12:10am here, and all shops are closed (including the store I bought the Ike gear from) - I will call off dive for Tuesday and look in to it...
    Ikelite has superb customer service - definitely worth a call and or e-mail directly to them (ikelite@ikelite.com)(317-923-4523). Skip the middle man.
    Good luck.
    Andy
  7. Ikelite has superb customer service - definitely worth a call and or e-mail directly to them (ikelite@ikelite.com)(317-923-4523). Skip the middle man.
    Good luck.
    Andy
    Great - Email Sent - I will post reply...
  8. You should dive a new housing without camera & move all the controls just to make sure everything is OK.
  9. Hi,
    I took a look at my D200 housing and my D70 housing and they both are set up just like yours.
    I have dove both housing without any problems.
    Hope this helps
    Stephen
    BUT
  10. I have D300 Ike housing and it is exactly like yours.
  11. ditto on my ikelite 20 D housing......
  12. My brand new Ikelite D80 case looks the same but it was not in water yet
    Michal
  13. ;) - I Love this forum - Thanks everyone. That is great news....
    I wonder why they did it - ?
    Anyhow - Thanks again.
  14. Response from Ikelite - All Good...
    Subject: Re: FW: D300 Housing Question...
    Thank you for the inquiry. The black seal that the customer identifies under the top latch is actually a black spacer washer rather than a seal. This black spacer washer is not needed for the two side latches. I apologize for the confusion.
    Regards, Duane / Ikelite
