olympus 410
Started by kento ·
  • 9Posts
  • 9Replies
olympus 410
  1. Hi
    have just start to use my OLY E410 afters a coupels of dive and about 30 image
    and can just say am not very happy about my image the are blur not very sharp
    think my old OLY8080 taken better image. But have som ???????? about this
    first a stsrt to wonder if a have the right port have ikelitedomport "6???????
    and if a need diopters for my lens (14-42 WA) can really understand it if need
    allso a was thinking to remov the shade of the domport?????
    and last ist very hard to see when a using my housing weiwfinder
    have tryout both whit and whitout rubber cup. need so hint
    regards kent
  2. Hi Kent,
    First remove the rubber cap as it can cause a problem in closing the housing correctly.
    Second no diopter is required for the 14 to 42 zoom if it is used with the correct port, flat or dome style, Ike recommend the 6" 5503.55 dome. The shade should NOT affect the image quality.
    Keep working at it, you won't learn any new system in thirty images.
    Phil Rudin
    Edited by tropical1
  3. Hi Kent,
    Second no diopter is required for the 14 to 42 zoom it it is used with the correct port, flat or dome style, Ike recommend the 6" 5503.55 dome. The shade should NOT affect the image quality.
    Phil Rudin
    Hi Phil yes agree
    have alot to learn and work whith but when a using the wiewfinder its look like a wiew tru
    a tunnel or pipe and lack of magnifier .Have try out whith rubber cup and whith out rubber cup
    allso its hard to see if the camera has focus on a object
    about my toghts to remove the shade was to let more ambient light to hit the camera for easy focus
    best reards
    kent
  4. Hi Kent,
    Phil Rudin
    Hi Phil yes agree
    best reards
    kent
  5. Hi Phil yes agree
    best reards
    kent
    You may want to also try a focus light to see if that helps. Is the camera working properly outside of the water in terms of quality? I had a camera that was out of spec and everything was soft but was quickly corrected by the manufacturer
  6. Hi Kent,
    I used the E-410 with the Olympus housing which has a decent pickup finder V. the cost of the housing. I can't speak for Iklite as I have never used their housings.
    The viewfinder is small but no more so than for the other cameras in the same price range. I don't have the greatest vision but I was still able to focus and frame the subject without a problem in average light. A focus light is a help and the superb 50 macro is an F/2 lens which will AF better in low light.
    I would use the camera in the housing out of the water to be sure you have the build in diopter in the proper place for your eyes and the housing diopter. The little dial on the top left of the viewfinder.
    Again, any system takes time to learn.
    Phil
  7. You may want to also try a focus light to see if that helps. Is the camera working properly outside of the water in terms of quality? I had a camera that was out of spec and everything was soft but was quickly corrected by the manufacturer
    Hi yes the camera is outstanding top side using my camera every day
    so camera is fine
    kent
  8. Hi Kent,
    Phil
    Phil yes is try olymopus has small wiewfinder vs nikon and canon
    but is very clear and bright . yes a have try out the rig out of the water
    have allso set the diopter on my cameras wiewfinder if that you mean
    as you say any new system take som time the macro 50mm look very nice
    going to have it and allso planing to uppdate 12-60 lens that looks very nice to
    phil trying to load upp som image here but does not work to big files??????
    thanks again regards kent
  9. Resize your image to 800 x 600 and it should upload fine.
