Smugmug Video now supported
Started by cor ·
  1. Hi all, recently SmugMug has added Video to their portfolio. As a customer of SmugMug you can now upload videos and share them with the world. Wetpixel now supports embedded SmugMug Videos. To add your video to wetpixel you need to use one of two tags in your posts.
    This will show a video of 425 width and 240 height. You MUST supply the height yourself, as SmugMug will otherwise crop your image to the wrong size. The width is set by SmugMug.
    [smugmug=240]ZT0xJmk9Mjg4NjEzNzIwJms9SkY4N3EmYT00ODE2MjI2X2J5eUxRJnU9dXdpbWFnZXNmb3J1bQ==[/smugmug]
    The following code will show a larger video, with a width of 640 and a height of 425 (remember to fill in your own height)
    [smugmugl=425]ZT0xJmk9Mjg4NjEzNzIwJms9SkY4N3EmYT00ODE2MjI2X2J5eUxRJnU9dXdpbWFnZXNmb3J1bQ==[/smugmugl]
    The Video ID you see needs to be grabbed from the share URL you get from SmugMug. It'll be pretty obvious to find. Here are two examples at smaller and larger size. Courtesy of Eric Cheng.
    [smugmugl=360]ZT0xJmk9Mjg4NjEzNzIwJms9SkY4N3EmYT00ODE2MjI2X2J5eUxRJnU9dXdpbWFnZXNmb3J1bQ==[/smugmugl]
    Edited by cor
