Sorry for being slow on the NAB reports but here is the Panasonic announcements for new camcorders. Building on the success of the Panasonic HVX200's tapeless camcorder system, Panasonic announced the AG-HPX170, a 1/3" CCD DVCPRO HD camcorder without the tape drive of the HVX200. The 13x Leica lens is 28mm at the widest, easily the widest fixed lens camcorder (the competitors float around 31-34mm).
The P2 system is a proven production codec used in broadcast. It is still unknown if the CCDs are still the same 960x540 sensors used in the HVX200, where many people complained about the resolution of the 1080i/p being poor compared to other cameras. Being CCD, it will however not suffer from rolling shutter effects, which is important for many shooters.
Panasonic AG-HPX170 Press Release
On the AVCHD front, Panasonic released a 1/3" 3 CCD camcorder, which is a mini-me version of the HPX170, using AVCHD codec and recording on SDHC and SD cards at 21mbps (max 24mbps) which nears HDV's MPEG2 bitrates. AVCHD is MPEG4 and more efficient but it was always held back by low bitrate, due to the slow speed of SD cards. Panasonic is the first manufacturer to break the 20mbps barrier. As a mini-me, it has the same 28mm wide 13x Leica lens and no tape drive. It does not do over/undercranking at 720P unfortunately but it does support 1080/24P/60i and 720P.
With AVCHD heading editing now coming around with the big editing suites, and the ability to play AVCHD on most HD players native is a boon for some shooters.
