I had been wanting to switch from my MacBook Pro to a MacBook Air for travel. My MBP is my main computer, and I have always worried about traveling with it and losing it or having it stolen. Before trips I would sanitize the laptop of files and other info that concerned me, then put those files back on when I returned home.
I use Aperture for my photos. I was concerned that the MBA would be too slow to tolerate. I use the word tolerate, because I fully expect the MBA to be slower than the MBP, but as long as the speed is tolerable for processing photos on site then I can live with it until I return home to a faster computer.
I bought a MBA on Friday, with the understanding that I would test it with Aperture, and return it if it was intolerable. I thought I would share my results in case any others are curious.
I shoot a Canon 40D. The raw files are typically 11 to 15 MB each. I took 55 photos with my camera. Normally I would import the photos with a FireWire card reader. However, the MBA has no ports other than USB. I therefore hooked my camera directly to the MBA with USB to import the photos. I did the same thing with my MBP for comparison. After import, I monitored how long it took to build all the jpeg previews. I choose to build full size previews at a quality level of 5. I then stepped through all the photos one at a time, waiting until the full RAW file had loaded before proceeding to the next file. This was to test the time it takes when adjusting photos, after finishing with one photo and waiting for the next to load.
The results are summarized below.
Read card and draw 55 thumbnails for import ... MBP 16 sec ... MBA 27 sec ... 69% longer
Import 55 photos ... MBP 111 sec ... MBA 133 seconds ... 20% longer
Build 55 full size jpeg previews ... MBP 193 sec ... MBA 304 sec ... 58% longer
Step through all 55 photos ... MBP 154 sec ... MBA 210 sec ... 36% longer
The import function only took 20% longer on the MBA. I suspect this is because the USB connection direct to the camera is the main limiting factor.
Building previews took 58% longer. Not surprising, considering that my MBP runs at 2.33 GHz, while the MBA is only 1.6 GHz. I suspect the processor speed would be the main factor in building previews. Another factor would be the hard drive speed. My MBP has a 200 GB 7200 rpm drive, while the MBA has an 80 GB drive at 4200 rpm.
Stepping through the photos taxes the hard drive and the graphics card. The graphics capabilities of the MBP are much better than the MBA. The MBA was 36% slower, likely a result of the slower hard drive and weak graphics power.
After the first test, I repeated the import and preview test the next day with 108 photos.
Import 108 photos ... MBP 232 sec ... MBA 264 sec ... 14% longer
Build 108 previews ... MBP 383 sec... MBA 635 sec ... 66% longer
Total for import and build ... MBP 615 sec ... MBA 899 sec ... 46% longer
My decision? Keep the MBA. It is definitely slower, but the speed is acceptable to me. I am willing to trade off the speed in order to get a smaller, lighter travel computer. I will be buying a USB card reader to see if it is any faster than directly connecting the camera. I will likely change Aperture's preferences on the MBA so that it does not automatically/immediately build previews. I will then download all cards in succession. Once the cards are downloaded, I will manually initiate the previews, while I grab a cold beer and kick back and relax and savour the memories of the day. ![]()
p.s. My thoughts on the MBA. Cool factor is off the charts! It is beautiful to behold and handle. The weight difference is huge. It makes my MBP feel like a boat anchor. There are many sacrifices, but none of them outweigh the final package. Kudos Apple. ![]()
