1 G9 + 2 YS-60's: Suggestions for connecting them?
Started by Phil Woodney ·
  1. I've been reading a great deal about u/w photography for the past few months and have begun assembling a setup based upon information I've gathered on Wetpixel. Fantastic information! But I've not found anything which seems to apply to my situation, hence my questions.
    I have a Canon G9...my first digital camera. I've been shooting on land for around 40 years, but couldn't find a housing for my 5x7 technical camera. I also picked up a couple of YS-60's to go with it. No housing yet, but I am leaning toward the Ikelite because of it's expandability. But in any case, I need recommendations for triggering the strobes. I've read of the Heinrich-Wehkamp TTL adapters and they seem to be an elegant solution. If I go that route, would you recommend one adapter and a double sync cord? Or should I use two adapters? Or is there another solution which you consider better?
    I'm open to ideas although I will add that I prefer to keep these strobes rather than sell them and buy another sort. I bought them cheap and don't want to shell out for Inon or Ikelite strobes. Diving in general is expensive and, as I am discovering, u/w photgraphy is even more so! :)
    Thanks in advance for your help!
    Phil
  2. I'm not familiar with the YS-60's - I use Z-240's with my G9, but I'd recommend fibre optics as the reliable and robust option...
  3. I took a quick look at the specs on the S&S site.
    They look like they only fire via true sync cable ... if that's the case and you are set on the strobes and a G9, your best solution would likely be an Ikelite Housing and a dual Ikelite to S&S sync cord.
    I think in theory you could also get a stand-alone Canon/S&S TTL converter to get TTL control, otherwise you are in manual mode only.
  4. In my honest opinion,
    I would think that you are on a winner by getting the Ike housing because that comes with Canon e-TTL converter installed. You can either sell or trade or swap your two YS-60's for a couple of Ike's DS-50's or 51's and have great TTL shooting.
    I know that you don't want to sell your YS-60's but a bit of homework before the initial purchase might have saved you from going down that route...
    You can, as you say, get hold of one of Matthias' converters and run a dual cord for the YS-60's.
    His converters work VERY well and the YS-60 strobe is an oldie but goodie...
    IMHO,
    Bruce...
    BTW...welcome to Wetpixel...
    Edited by bruceterrill
  5. In my honest opinion,
    IMHO,
    Bruce...
    Do the TTL converters work with the G9 for sure? I don't see why they wouldn't ... but haven't ever heard of anyone doing that - prolly 'cause if you want G9 with TTL you buy the Ikelite strobes ...
  6. My advice would be to check the compatibility of the YS-60's w/ the TTL converter and the G9. I'm not sure if the strobes are compatible - I remember reading that they required a modification.
  7. Thank you all for your help! Regarding compatibility, the YS-60's I bought are the latest version, bought directly from Sea&Sea U.S. According to the Heinrich-Wehkamp site, they work fine with the G9 via the TTL converter without modification.
    I agree that it would have been perhaps better to go the full Ikelite route, but funds are limited. So I have to make a sort of piecemeal approach. Before I invest more on strobes, I want to see if this setup will perform well enough. I can sell these strobes at a profit if it doesn't work well.
    Again, thank you to each and every one who replied. It helps a great deal!
    All the best,
    Phil
