eTTL / iTTL on Digital SLR : satisfied ?
Started by steph ·
  1. Hi,
    I red severals threads speaking about, converter, iTTL and many time it ends
    up with the word "compensation".
    My concern is to have a picture exposition spot on right out the box (no pp).
    I have used differents setup like single or dual DS-125 with Mathias eTTL
    converter on Canon system and I found it not reliable. Sometime it works and
    sometime you have to struggle to found the perfect exposure compensation
    and in many case it is not nearly perfect.
    I have then switched to Nikon and used my Subtronic and Inon on it both in
    manual. After a few dives I was able to guess the exposure and it was right
    what I wanted (both in macro or wide-angle).
    A few month ago due to problems with my subtronic I bought an SB800 and
    a Subal housing. Try to use it in iTTL. Found the exposure not consistant and
    have to go back to compensation or switch to manual.
    Now I use my SB800 in manual mode (both with Inon) and found the exposure
    more accurate and overall much more balanced than in automatic.
    If compensation is a must (to reach accuracy) when using TTL flash for me it
    meens no more 'automatic' : sound not so helpfull for me ?
    Now if you have to identify the situation for which the TTL will not work then
    is it far different than using manual ?
    Just some thought to share with you.
    Regard
    Stéphane
