ikelite
Started by kento ·
ikelite
  1. Hi You all
    Need som suggestion hints for focus light on an ikelite
    housing whit out hotshooe ho can mount it
    thanks
    kent
  2. Hi You all
    thanks
    kent
    I have mine attached to a small arm on a triple-clamp off my tray handles ... here's a picture:
  3. I have mine attached to a small arm on a triple-clamp off my tray handles ... here's a picture:
    Hi nice a whant it to but can"t get tripel clam in sweden
    thanks kent
  4. Hi
    No problem, just order online from the UK. These are small parts that will fit readily into a padded envelope and can be sent standard mail - may take a week or so to get delivery, but shouldn't add too much to the cost.
    I have to do this all the time as I live in Bermuda and there is limited shopping available
    Hal
  5. Another (and better I think) option is the AC-NB from Ultra Light
    Edited by Arnon_Ayal
  6. Another (and better I think) option is the AC-NB from Ultra Light
    Following this link, it says that it will not fit Ikelite arms - so whilst a good idea, may be less than ideal here - depends which arms Kent is using
    Hal
    Edited by Halabriel
  7. Following this link, it says that it will not fit Ikelite arms - so whilst a good idea, may be less than ideal here - depends which arms Kent is using
    Hal
    HI Have Inon ball arms
    And Ultra light Handel on
    a ikelite tray
    regards kent
  8. I already had a small LED lamp so I took
    - half a plastic pipe
    - drilled two pair of holes in it.
    - Attached it with cablebinds to the flash
    - velcro bind between the pipe and the flash, to hold the light
    This way I can be almost certain where the strobe will be pointing at.
    The strobe has a warmer light than the light and it doesn't show up in the pictures, so I don't need to turn it off before shooting.
