Mixing arm parts from different manufacturers?
Started by Marjo ·
  1. I know this might seem like a weird question. Could you use clamps from ULCS to connect Ikelite arm sections (with 1" balls)?
    I don't really mind the ikelite arm sections that I have, but the Ike clamps are a bit big and I would like to relace them with something a bit smaller.
    Anyone knows if this is possible?
  2. I know this might seem like a weird question. Could you use clamps from ULCS to connect Ikelite arm sections (with 1" balls)?
    Most 1" (North American) and 25mm (European) ball arms sections and clamps can be mixed with no problem at all - I've tried quite a variety from Ultralight, Seacam, TLC, Ikelite, Inon etc and found no problems with the items I tried.
  3. I've used a mixture of TLC and Ultralight for ages, with no problems. I like the TLC wheels, but the Ultralight clamps can be a bit easier to turn. They both work with Inon, but I haven't tried Ikelite fittings.
    Tim
    B)
  4. Yes, I use Ikelite and ULCS 1" balls together. I like the bouyancy arms from ULCS and their clamps, but I like the detachable arm segment from Ikelite to give me lighting options.
  5. Yes.
  6. Thank you all!!!
