COPY RIGHT LOGO ON CS3
Started by Brian Harris ·
  1. Hi,
    It been a long time since i have used it, but can anyone tell me how to get the copy right logo up on CS3.
    Regards
    Brian
  2. are you using a PC?
    go to windows accessories-system tools-character map and just copy and paste from there.. that is what i do. there is a keyboard shortcut but i am not sure what it is :)
  3. On the PC try doing this:
    Press the “ALT†key and while doing so, type in 0169 on the number pad and not on the number keys at the top of the alphabetic part of the keyboard (it will not work if you use the numbers at the top of the keyboard). This is the manual way of typing ASCII characters and will work with any font that you are using to type in your copyright notice.
    I am not sure how you do it on the Macs though.
    A quick search for copyright mark or something similar should bring up lots of threads on different copyright notice techniques used here by different Wetpixel members.
    Hope that helps.
  4. On a Macintosh you press option-g
    like so:
