Do i need a diopter ?
Started by Big Blue One ·
  1. I just recently acquired the ikelite 8" super dome for my rig.
    I tried it out at PG and noticed that there were some issues in nailing the focus on some of the wide angle shots.
    http://www.pbase.com/richardfoord/image/97168874/original
    and
    http://www.pbase.com/richardfoord/image/97168876/original
    previously I had borrowed a friends 6" dome and even in low viz seem to have got reasonable results in Sydney
    see
    http://www.pbase.com/richardfoord/image/92608568/original
  2. I just recently acquired the ikelite 8" super dome for my rig.
    Where in the frame does the problem appear? The edges are probably never going to be right with a wide zoom, and whilst a diopter can help, some edge problems often persist. I don't have experience of your particular rig to give a suggestion, but +2 - +3 D works for similar lens/dome combinations.
    Tim
    B)
  3. I just recently acquired the ikelite 8" super dome for my rig.
    and
    see
    I think the corner is looking soft on the last image as well (down left). As Tim said, this is a common problem of wide rectilinear lenses behind domes. A dioptre might give you better results, it's worth a try. Can't comment on what strength you would need. Also check that you have the proper extension for the port (if needed). Your housing manufacturer should have specific reccomendations for optimal performance.
    good luck
    /christian
