AquaLung Slingshot Open Heel Fins
Started by diggy ·
  1. Am very happy with my Mares Volo Power but they are way past their optimal levels. I tried Scupa Pro Twin Jet max BUT found them a little heavy and cumbersome also a bit tiring, after being used to the lightweight Mares. I am most likely going in for another pair BUT was curious to know if anybody has used these new Sling "Shots" ? Also how heavy are they ?
    Diggy
    Edited by diggy
  2. I'm quite new to diving in general (about 55 dives to date) and have little experience with other fins... but having dived 20 dives with these I have to say I like them a lot. I use them on easiest setting and hardly feel them on my feets kicking and give quite good power. I got the impression that they are slightly bigger than normal fins so you might want to check that in the store in case you want something compact/light. Weight is about 1 kg per fin.
    The only thing I found a tad annoying was that sometimes you hear/feel the power bands snap and felt almost like you slightly touched the bottom/corals.
  3. I'm quite new to diving in general (about 55 dives to date) and have little experience with other fins... but having dived 20 dives with these I have to say I like them a lot. I use them on easiest setting and hardly feel them on my feets kicking and give quite good power. I got the impression that they are slightly bigger than normal fins so you might want to check that in the store in case you want something compact/light. Weight is about 1 kg per fin.
    Thanks Whizzer for your input. I kg sounds a bit heavy but i assume with the 3 adjustments it may be easier once below water. Unless i get to try them when i travel to Thailand next month Ii will probably opt for the Mares. BUT your input has been a great help.
    Diggy
  4. IMO and this is not having tried them I would suggest that the Slingshot is over complicated and is likely to break often too. However if your Vollos lasted a while without breaking maybe you get lucky with fins.
    It seems over kill for a pair of fins. I couldn't see myself ever changing settings, especially in water.
    The only reason I ever bought a pair of split fins was they were small and light for packing up. I personally still think the best fin ever made is Mares Avanti Quattro Power, long solid and powerfull, but not great for travelling now a days.
