Newbie DSLR user, (D300/Sea&Sea housing) happy rant & review...
Started by eskasi ·
  • 11Posts
  • 11Replies
  1. Just got back from a great trip where I got to dive Cozumel, Roatan, Belize, Bahamas and Bodrum (Turkey). It was also my first time using a DSLR rig and I was kinda nervous. My fears were unfounded though and I managed to get acquainted with my new baby fairly quickly. Here is the gear I used;
    D300, Sea & Sea Housing & TTL converter
    Inon 45 deg viewfinder
    Fisheye HG20DX
    Stix arms
    Optical Dome port
    Standard Port (With Woody's Diopter)
    Athena 105VR Macro Port (with Inon Wet Diopter up front)
    Lenses;
    Nikon 105VR F2.8 Macro
    Nikon 60mm AFS F2.8 Macro (new model)
    Nikon 10.5mm F2.8 Fisheye
    Sigma 18-50 F2.8 Macro HSM
    I thought I might share some of my experiences as I had to do a fair bit of research on some of these items before my purchase...
    First of all, I definitely found the 60mm Macro to be the most versatile lens. The new 60mm AFS fit nicely with the Standard NX port. Also, after doing a lot of research on how to use the Woody's diopter with the Standard NX port via mods, I found that the Woody's largest size (110) fit the standard port nicely! All I had to do was to cut two slits on the diopter so that it would fit (snugly) over the oddly shaped rubber front of the NX Port. The 60 internally focuses and the AFS is really quick. Not once did I feel the need for manual focusing although that may change as I get better at this! The Woody's really helped fill the frame and I highly recommend it. However, I found myself forgetting to take it off at times which made taking fish portraits/non-macro shots impossible of course. Here are a few shots I took with the 60;
    105VR Macro, Athena port, Stix arms and Stix Buoyancy collar. This combination allowed for a slightly negative camera rig underwater (together with 2 YS-110 strobes). I found myself using the 60 more than the 105 macro. This was usually because throughout the many weeks of diving, I dove many different new locations and as such was hesitant to use such a specialized lens. I only took down the 105 if I was diving the same site and there were Macro opportunities there. When I did, I also had an Inon Wet diopter with me for super macro possibilities. Sorry, just one example to show here...
    Sigma 18-50mm F2.8 HSM Macro, modified Nikon Zoom Gear, Optical dome port and SX Extension ring. I had thought this would be my "all round", "not sure what I'll see" lens. I was wrong. I found the 60 macro to fit that bill better. I suppose I am more of a fish portrait/macro person. When I wanted to do reef scenes, I went straight to the fisheye. I did use this lens when I expected to see sharks or rays. True to the posts on this board, the lens performed very well in this capacity. However, at times, I found the 18 wide to be not quite wide enough.... Sadly, I saw only one solitary shark (big or small) on my whole Bahamas trip! It was too far away and I did not even bother attempting a shot. Here are a few examples from this lens. The Twin smiling Remoras won me the photo competition of the trip. A very proud accomplishment for me given that it was my first time using this lens and a dome port underwater.
    I call this picture below "The Pied Piper" The three remoras were actually heading off to harass the diver in the distance!
    Finally, the Nikon 10.5 Fisheye lens. I was lucky enough to have a friend with this lens who loaned it to me for this trip. He shoots topside and barely has an opportunity to put this beautiful piece of glass to good use. I was hesitant to use this lens for a while as WA shots never really interested me. Boy was I wrong! I love this lens! It is tack sharp, works far better than I expected in cloudy (less than gin clear) water and allows for some creative possibilities. Yes, it is VERY VERY wide....CFWA shots need to be done really really close to the subject! The Barracuda in the picture below was 3ft long and about 2ft away from the dome port! The social feather dusters were almost touching the glass!
    All in all, I was a very happy DSLR user. I started the trip more worried about floods and lens choices.... after a few days, This didn't bother me anymore. Even in heavy current, I managed to handle the gear without too much trouble (although the floppy arms was a slight pain. I wish Stix ball joints had the Rubber O-ring like Ultralight arms). The 45 degree viewfinder took a little while to get used to. Even for macro, I found myself hunting a little for the subject. Once it was found, tracking it was simple and so was maintaining my position (due to the 45 degree angle). WA shots seemed simpler to get used to with the 45 deg viewfinder. This was probably because there was no subject to hunt/track (or the subject was easy to spot in the case of CFWA).
    The D300 was incredible. I shot mainly at ISO400 and at times 200. Autofocus was fast and trouble free. I found myself hardly using the focusing light even in tricky situations. The Fisheye light came in very handy during night dives of course!
    The Sea & Sea housing was easy to use and all the functions easy to reach. My only gripe was that my thumb could not reach the Circular D-pad buttons used to move the focus point while my hand was holding the handle. I had to let go of the handle and place my hand on the housing itself (on the inside of the handle) to be able to reach both the shutter and the manipulate the buttons while keeping my eye on the viewfinder. I may mod a soft handle/strap so that I can do this while still supporting the camera with the same hand.
    I hope this post has been helpful to anyone starting out in DSLR and thinking of getting a similar set. I also just had to share my happy experience and some of my first novice shots. There were many more but I think each post is limited to 10... lol.
    Thanks for reading!
    :D
  2. You have a very nice series of shots there to be proud of. Nicely done.
  3. Great report and wonderful images. Thanks for sharing both.
  4. Very nice; I really like the first ramora shot.
  5. How was Turkey? I have family there and have long wondered what the diving is like. I've been told (by Turks) that is as good as the Med gets, but I have no idea how good or bad the Med is ...
    Are there any underwater archeological sites?
    P.S. Your pics look great!
    I'm resisting the SLR thing, but I don't know how much longer I can hold out ... if The G10 comes out with a CMOS sensor and fits in my G9 housing, I may be able to resist for another year or two ...
  6. Hey Jeremy,
    I've been diving in both Malta and Bodrum as far as the Med goes. I must say that it isn't too great. There is little sealife. In Malta, the DM's were excited to see any kind of decent sized fish!
    Bodrum had it's moments. Octopus, some Morays and quite a few little wrasse and other small fish. The reef did not have much coral life but did have sponges. Then again, I believe diving in the Med is more famous for it's underwater structures/formations.
    Having said that, I was happy to be in the water regardless. The few dives that I did gave me some good photo ops too. Vis was good and there was no current whatsoever. You will not be able to get close to any archeological sites. I would have loved to dive those (even if under close supervision/scrutiny). However, the Turkish gov is really paranoid about this and such areas are completely off limits. ALL divers in Turkey must be accompanied by a DM guide which is registered with the dive association. To be caught not doing so means risking having all your gear taken away and getting a massive fine! This penalty also applies to operators who for any reason allow unguided dives. As such, everyone in Turkey follow these rules quite carefully.
    I did it because I had a chance to try it..... I doubt it would be high on my list of places to do dive travel. However, for those who must live with 1m vis and still see nothing but rocks and some greens, it could be heaven.
    Here are some of my other pics from Bodrum (In addition to my Hermit crab shot above);
  7. great photos and rant/review. congrats on your 1st,2nd,3rd, 4th, and 5th trips with your new rig.
    I especially like photos #7,8,9, & 10
    keep up the nice work
    Scott
  8. All those places were one "trip"??? I want your job! :D
    Seriously though, very nice shots for a 'first time' DSLR user. Better than mine, quite frankly!
  9. All those places were one "trip"??? I want your job! :D
    Lol, Thank you for the compliments..... I did all those places because I went on a week long cruise to the Western Caribbean diving at every stop (yeah...DSLR Rig and all my own gear!), then did a 1 week trip on the Nekton Pilot to Medio Reef, followed by a week in Bodrum while on my way home.... I was also in Daytona Beach, Orlando and NY for a while but did not dive there.
  10. Lol, Thank you for the compliments..... I did all those places because I went on a week long cruise to the Western Caribbean diving at every stop (yeah...DSLR Rig and all my own gear!), then did a 1 week trip on the Nekton Pilot to Medio Reef, followed by a week in Bodrum while on my way home.... I was also in Daytona Beach, Orlando and NY for a while but did not dive there.
    fantastic review and killer pics. Im off to google woody's stuff now!
  11. Thanks for the write up. I'm about up a DSLR rig - essentially what you got - and know I will have first time jitters taking into the ocean for the first time - I was the same was with my Nikonos'. Glad things went smoothly. And like the others said - nice photos. The remora shot is particularly good - you nailed the composition on that one.
    And speaking of wide angle oppurtinities - I saw a show on Raja Ampat on Discovery HD last nigt - now thats a place to give a fisheye a workout.
