Hey Pete,
I was shocked at how different my FX1s behaved compared to my old (and still highly reliable) PDX10s when manual white balancing at "depth"....
PDX10s - 25m no problem... colours..... on a cloudy day? great......
FX1s - achieving MWB at 15m depth is VERY lucky..... colours at 30m on a cloudy day? really rather grey.....
no matter what a manufacturer states about minimum Lux levels etc... the FX1 is still cramming a hell of a lot more pixels into a CCD than with SD cams.... these pixels are smaller than older SD pixels and hence the cam is actually far less sensitive to light. It, therefore, has (what I would claim to be) serious issues with white-balancing off fairly healthy natural light levels.....
I don't know if you are using the Electronic MWB option on the right control grip or whether you opted for the Wags class Mechanical MWB add-on....
I use the "Wagsy" MWB option - this also led to issues at depth (passed 20 or so metres) as the pressure forced the MWB button (the old ND filter knob) into the housing: activating the MWB.... as long as the ND filter MWB knob was depressed, all functionality (manual iris etc..) was lost from the cam whilst it was seeking correct WB....
The fix for this was to cut a couple of mm off a half inch PVC pipe and create a "C-clip" out of it. The clip is then tied onto a little piece of elastic and that is, in turn, tied off onto the base of the grip.... It sits between the housing and the ND filter knob and stops it from being pushed in by the pressure - when I want to use the MWB I simply unclip the clip, use the function and then snap it back into place...
I'm not sure if this post will help you too much, I hope it does - half of me thinks that it just boils down to the FX1s inferior ability to impress me (in SOME ways!) as much as certain older SD cams did......
good luck
