Some from Pemuteran/Menjangan - Bali
Started by diggy ·
  • 14Posts
  • 14Replies
  1. Had gone with the family to Bali last month for a holiday. Managaed a few dives at Pemuteran and Menjangan. Here are some of my favourites.
    The rest can be found on flickr at
    http://www.flickr.com/photos/14232146@N08/...57605406848800/
    Diggy
    very nice shot there!!
    did you used short port for wide and macro shot during this trips?
  2. Very nice pictures , I love especially the macro wide angle with the leaf fish !!
  3. Thanks girelle and sweesin.
    Yes sweesin, i used the short port. In fact i now permanently use the short port.
    Diggy
  4. You're welcome !!
    I also use only the short port for my G9 in Patima housing , for wide angle and macro as well
  5. how much zoom you can do with the short port?
    does short port produce any dark edge when using macro lens??
    hope it can do half of the zoom length, then it might solve my problem.
  6. how much zoom you can do with the short port?
    Hi sweesin,
    You can zoom a little over 50% One has to be careful not to zoom more cause the lens jams. You then have to switch off the camera and switch it on again.
    No dark edges when using macro lens. But with the wide angle one has to zoom out a little to avoid dark corners and vignetting at the edges.
    Diggy
    Edited by diggy
  7. Very nice - I like the close focus wide angle leaf fish shot.
  8. Very nice - I like the close focus wide angle leaf fish shot.
    Thanks James , :)
    :D Cheers,
  9. Hi sweesin,
    Diggy
    even with short port still need to zoom to eliminate the black corner?? :D
  10. even with short port still need to zoom to eliminate the black corner?? :D
    Yes even with the short port you still have to zoom out ! :)
    Diggy
  11. Yes even with the short port you still have to zoom out ! :D
    Diggy
    No need to zoom with the Patima housing !!
  12. No need to zoom with the Patima housing !!
    Hi Girelle,
    I started thinking that patima must have a really short port after reading your reply and read this on their site under wide angle lens:
    http://www.uwcam.com/eng/products/sub2_1.html
    "When the exclusive port for wide angle is applied 67 mm mount wide lens is able to be used. The zoom must be fixed to maximum so it is not possible to use zoom "
    Why then do you need another port as the site says for normal lens, when you can fully zoom out on the short port ??
    Also if you are fully zoomed out wont this decrease the angle of view ?
    Sorry just got a little confused on the above..and thought i should ask, as i realy liked the look of this housing and how compact it is.
    Diggy
  13. Yes even with the short port you still have to zoom out ! :)
    Diggy
    then it mean you are not using the widest from the lens ... :D
    so how much gain from using the wide angle lens??
    as from inon website ... UWL-100 shld able to provide 100 degree of view ... :D
