Ikelite Strobe/housing compatability vs. INON
Started by mbutler ·
  1. I have read about the many advantages of the INON strobes, however, I also have been told that the strobe and housing for Ikelite are synched and that you do not need to adust the lighting on the strobe if it is overexposed, etc.
    Can someone articulate what the actual benefit is to buying the Ikelite strobes w/the housing (for a G9) vs. using the INON and what specifically you would need to do with the INON strobe in terms of manual adjustments, etc.? Trying to figure out what the best solution would be.
    Thanks!
    Maria
