Make Reasonable offer D40X w/Aquatica Housing
Started by DirkPitt ·
  1. Used Nikon D40X ($ 549.00) & Aquatica Housing ($1500.00) with 6†Wide Angle Dome Port ($300.00), Optional AquaticaAqua View Viewfinder ($1165.00) Total Value of $3514.00 Offering for Only $2950.00 or best offer.
    Used for 5 months, upgrading to D300. Need to move fast. email brad@divechronicles.com
    This Aquatica housing for the D40X has a cast aluminum body that is anodized and machined to exacting specifications. It operates safely to a depth of 200' (60 m).
    The lens port has a positive bayonet mounting system, which leaves no doubt that your port is securely in place and watertight. The bayonet system offers fast access to lenses for rapid changing. There is also a lens release button on the front of the housing to facilitate easy lens changes. The housing allows use of lenses ranging from Fisheye to the 200mm Macro.
    The Aquatica D40X housing uses a viewfinder that delivers a big and bright image and full frame viewing to your eye. LCD information in the camera's viewfinder is easily referenced while shooting, and chromatic aberrations have been significantly reduced for sharp focusing and exact composition.
    The compact Nikon D40x -- designed to deliver the picture-taking benefits of a digital SLR, yet is easy and fun to use. The D40x is ready to shoot when you are, thanks to split-second instant shutter response which eliminates annoying shutterlag. Exceptional image quality is made possible by a high resolution, 10.2-effective megapixel CCD image sensor and Nikon’s exclusive image processing engine.10.2-megapixel resolution invites creative picture cropping freedom without loss of picture quality and delivers the ability to make enlargements of extraordinary size.Additional features include built-in flash with innovative Nikon i-TTL control, In-Camera Editing features with Nikon D-Lighting, Red-Eye Correction, ImageTrimming, Image Overlay, Filter Effects and more. An ingenious HELP Menu with "Assist Images" helps you select the appropriate settings for many camera features.
  2. Hi
    If the housing d40x is still available. I would offer $1000 for the d40x housing and the dome port. I would like to see a few pics also.
