NIKON 105 mm VR with Canon 500D
Started by pieterrutten ·
  1. Hello,
    I'm using a NIKON 105 mm VR macrolens and thinking about adding a Canon 500D
    close-up lens to get greater magnifications.
    Can anybody who uses this combination tell me how many extra millimeters I need in my
    port to house the 105 VR + Canon 500D + stepupring?
    Thanx!
  2. I think that Alex said recently that he was using that combination . . .
    From memory, he uses a Subal housing.
    Bruce...
  3. I think that Alex said recently that he was using that combination . . .
    Bruce...
    Yes he does, he advised me to get the canon 500D instead of trying to obtain a
    Nikon 5T. He also warned me for the extra space needed for the stepup/down ring and
    the 500D. (thank you Alex!)
    I'm using Ikelite housing and ports, and before ordering the closeup lens I want to
    make sure the combination fits in the port...
  4. Well it only seems fair, as I learned about the excellent 500D here on Wetpixel (from James). The 5T is good too, but hard to find. I shot the 5T on Friday.
    I just measured my 72mm 500D with a 62-72mm step-up ring (with a ruler, no calipers) and it is 16mm. So I would leave 17-18mm to be safe as not all step-up rings will be the same, or will screw flush onto lens and dioptre.
  5. Thanks again Alex!
  6. I just measured 17mm for my canon 250D + 62-58mm step down ring, with my 105mm VR lens...
    I use the 20mm extension ring and it works great.
    you can save a little money and weight by buying the 58mm diopter instead of the 72mm diopter. but I cant' promise it will work if you ever go full-frame.
    Scott
  7. Hi Guys,
    I'm interested in who you buy your step-up, step-down rings from?
    Also what brand/company they are from??
    Bruce...
