FS macromate flip close-up lens for SLR
Started by photowahine ·
  • 10Posts
  • 10Replies
  1. I have a macromate flip lens for close-up. Used only 1 dive, in perfect condition. Will sell for $425. New this is $540.
    easier for me to US only thanks
    Marcy
  2. I have a macromate flip lens for close-up. Used only 1 dive, in perfect condition. Will sell for $425. New this is $540.
    Marcy
    Marcy,
    what size is your macromate, which port will it fit?
    thanks
  3. I have a macromate flip lens for close-up. Used only 1 dive, in perfect condition. Will sell for $425. New this is $540.
    Marcy
    Hey Marcy, Why are you selling the macromate? Did you find it too hard to use? I tried one on one dive in Bonaire and it seemed like there was a pretty steep learning curve.
  4. Marcy,
    thanks
    It fits my subal macro port not sure what else it will fit but I can find out if you'd like
    Marcy
    I have a 20D which does not focus well under low light conditions and it just wasn't what I wanted.
    I only used it once.
  5. It fits my subal macro port not sure what else it will fit but I can find out if you'd like
    Marcy
    Marcy,
    Which specific Subal macro port? Is it the 105 VR?
  6. Marcy,
    It fits the flat port for subal, but not the 105VR
    Marcy
  7. It fits the flat port for subal, but not the 105VR
    Marcy
    Marcy,
    I believe that the macromate can only be used with the 105Vr port, not the 60mm port
  8. The slip on macro mate will physically fit on the ports but you will find the focus distance is reduced to point where its use is not a viable option.
  9. Marcy,
    This is the macromate flip lens
    I use it on the subal flat port with an extension ring for the canon 100mm lens
    I will check today but think the 105VR is a wider port
    Marcy
  10. This is the macromate flip lens
    Marcy
    This macromate will fit any subal flat port, but not the 105VR
    It might be possible to modify to fit other housings
