FS Nexus D70 Housing
Started by jcclink ·
  1. Just upgraded from D70 to D300, so D70 housing will be available. just as soon as I can dive the new rig. Basic housing only (includes handles, spacers, internal drive gear for 105VR, o-rings). No floods or leaks.
  2. Hi Jim,
    Maybe a 20mm port extension ???
    Bruce...
  3. Hey Bruce
    Still need all the add-on parts for the 300. Using the 40 + 20 for 17-55mm & 105VR. Sorry.
    Jim
  4. Hey Bruce
    Jim
    Sorry Jimmy,
    Yhis is slightly off post...
    But what are you housing the 105VR in?
    I've been trying to use the 'old' 105 lately and it's a shocker trying to AF on tiny critters!!!
    Bruce...
    BTW...anyone reading this thread should really understand how GOOD the D70/Nexus combo is... :)
    I love mine to bits, and it is a great unit for anyone starting out with DSLR. . .
    There are very few things that can't be done with this combination...
  5. Hi Bruce
    Using the 105VR with standard 60mm port (not the new "larger" version) & 60mm of ext ring (40+20). The port with 40mm ext ring (like for old 105) will not clear the VR gear sleeve, but adding an extra 20mm ring avoids this problem. Works fine. Note - sometimes the VR AF seems a bit too fast.
    Jim
